Just bought it too, brand new less than 24 hours old (yes I know lol) and my roommate threw away the receipt....bought it from a seller off of Amazon.com
SOURCE: bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
SOURCE: How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
SOURCE: HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
SOURCE: Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
SOURCE: i have a motorola n136 bluetooth and i lost my
Go to www.motorola.com and go to the support page.
