Good afternoon My startup shows the message "CHASSIS INTRUDED....SYSTEM HALTED" In the BIOS, there's no option for "SYSTEM SECURITY" or "ADVANCED BIOS FEATURES", so i cant change any options for able or disable anything about the sensor of opened chassis.. Anyway, the jumper is in the right position for DEFAULT to not display this message. So, what I cant do ? I'm losing my mind .. Please, show me the light for this .. Thanks
Hi, have you got this board installed in a case, with all the connections made? Usually there's a two pin connector to a microswitch that detects if the case is open. If you can identify that on the board you can short the switch, fooling the system into thinking the case is closed, to get inot the bios etc.
Apologies; you've already found this. If you've made this connection then it should boot. If not, remove non-essential components until it boots (drives, RAM, fans). This may well be a dodgy cpu or case fan, causing this error.
So SXTechHead, I thank you for your suggestion, but i'm trying to make this mobo runs only with the memories plugged, just for test..
ok understood. You do have a cpu fan plugged into the board?
SOURCE: chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
