When i give print command of any document in more than one page the first page print good but from second print it print one inch shifted from real place
SOURCE: 2 sided printing problem
What driver did you download? The PS driver is much less capable and I am wondering if thats what you downloaded.
I am using the PCL driver and the selections are 1 sided, 2 sided long edge , 2 sided short edge.
Unless you are runnung CAD, you really should be running a PCL driver.
Maybe I am misunderstand what you are telling me also.
If you have the PCL driver and thats still a problem let me know and I will forward all I can find.
SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
SOURCE: Xerox Phaser 8560
On the right side of the machine. There is an encoder mounted to the end of the drum shaft. They are known to become contaminated with the silicon lubricant from the maintenance kit. That causes the drum to spin off speed somewhat randomly. You can take it off the shaft and clean it well with alcohol. Sometimes they need replaced, but if it is as intermittent as you are suggesting cleaning it should take care of your problem. Not all that uncommon.
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
