When I try to enter a password the button to press ok is no longer highlighted. I tried resetting the modem, restarting the phone, and even did a hard reset to the phone. Nothing works. Can anyone help..
Instead of hitting connect hit the forget button. If that doesnt work then factory reset your device. Turn power off to the device then hold the power, home, and the volume up button at the same time after the first sign of it powering up release the power and home buttons while continuing to hold the.volume up until the android symbol appears and gives you the options to do a factor reset. Scroll down to the factory reset then hit the power button. Oh use the volume buttons to scroll up and down to get to it. Hope it helps..
SOURCE: LG KP202 - Needs security code
You have permanently locked the phone. Call your carrier and explain to them. But it is prob dead for good.
SOURCE: trying to sync music onto my lg dare
Instead of doing the sync music, try saving your music into your itunes account or on a flash drive. Than just plug your phone into the computer, click on settings, then tools, then USB mass storage. Open the file on your computer, than simply drag and drop your songs from the file on the computer or flash drive, into the phone's file folder. Drop it into your memory card on your phone or just in my music. (I personally recommend getting a micro SD card for the phone so you can hold more songs) good luck!
SOURCE: I can't check my voicemail...HELP!
There's a setting in your phone called HTMF tones. That needs to be on.
HTMF tones is what converts button presses into information an automated system would understand ... If it gives you an options of either long or short ... short is usually standard.
Hope this helps.
SOURCE: We purchased a LG Neon GT365 phone with a password in the phone
Look yuu go to tha main menu then yuu go to uhm;go to more then yuu go to were it say Security and yuu enter tha last 4 digits of ur phone and it show yuu your options and yuu will pick;Change Lock Code
