First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Owner-Center/Contact-Us/
*** following is for information only ***
* Checking basic problems; https://www.youtube.com/watch?v=SXJrVGP_Ixs
* The humidifier will only run if the "Humidity" (water or moisture in the air) is higher than the current setting on the humidifier. If it's set to maximum dry setting then expect it to run almost 100% of the time. If it is set to a "wet" setting then expect it run only for short periods.
* Colder room temperatures will reduce the frequency of cycles as cold air will hold less moisture than warm air.
* You may note that running a AC unit in the same room as the dehumidifier will give you mixed results as both units will "fight" or work against each other. Humidifier will heat the air as it exits while the AC will cool the air. Best to not run the AC while the dehumidifier is in operation.
* Note that AC do "dehumidify" the air as it passes through. But not as effective as a dedicated dehumidifier.
* Be sure to check the tub and filter (make sure they are seated properly.)
* Contact Frigidaire or your local Appliance store for service.
Aloha, ukeboy57
Sounds like you're in a wintery environment. Most people operate a humidifier in those locations because the air is too dry. If that is your situation, I suggest you turn the dehumidifier off until Summer and save electricity. If will pull moisture out of the air in the summer.
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
