KitchenAid KHMS147 Microwave Oven Logo
A
Anonymous Posted on Jun 05, 2014
Errore e7 bompani
Lavastoviglie
E-1 error on my microwave
Take your pick on the MAKE! Google search query on this is
make model error E1
Samsung microwave error codes
https://www.samsung.com > support > TSG01110365
A reference list of microwave error and information codes for Samsung microwaves. ... Close Menu. Open Search Layer; Cart Number of Products : 1; Sign In. Sign In / Create Account · Why ... Unplug the microwave or turn it off at the circuit breaker. If it's possible that ... E-04. Cooking Time Setting Over Error (Convection) ...
How to fix SE Error, 5E error, and E1 Error Fix - YouTube
https://www.youtube.com > watch
5:13 Understanding E1 error, 5E error or SE error. ... Your browser can't play this video. ... SE error ...
Oct. 30, 2018 · Uploaded by Technoo Lab
Can you please assist with Breville mode LMO530 Error E-1 ...
https://www.justanswer.com > ... > Appliance Repair
Nov. 20, 2020 - Yes, this is a system protection fault. The components attached to the main board are checked by the main board when a microwave is in use. 1 answer · Top answer: Thank you! Have a great weekend.
Oyster microwave error code E1 - Fixya
https://www.fixya.com > Forum > Microwave Ovens
Jan. 8, 2018 - No E1 error codes shown for this model of microwave! Have you checked your manual! Oct 7, 2014 GE JES636WK 700 Watts Microwave Oven. 1 ... Hotpoint JE740WY/GY Microwave Oven "Error code e1 ...
Nov. 23, 2019
E1 fault Samsung microwave CE1113f What to do
Aug. 17, 2018
How do I fix error EA1 code on my samsung microwave
Sep. 28, 2014
Oster Microwave E1 error
Mar. 6, 2018
More results from www.fixya.com
F2E1 - Error Code - Over-the-Range Microwave - Product ...
https://producthelp.whirlpool.com > ... > Starts with F2
Apr. 30, 2021 - There may be a problem with the User Interface / Keypad or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) ...
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
E7 fault on bosch oven/ microwave
this means a control board problem . However follow this steps: use the common sense and carefully. God bless you
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
Bompani microwave oven bo 23dgs user guide
i Need a User Manuale for the Bompani micrwave oven bo 23dgs
43helpful
4answers
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 [email protected]
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
When we start the microwave and push the start button instead of 30 seconds 15 minutes appear.No other button including start button works.It stops working only on opening the window of the microwave and...
That normally means the board needs to be replaced. Without wanting to explain all the details, im almost sure the keypad is still in good order.
2answers
Whirlpool Microwave Oven GH9185XLB1
You may have a bad control board. Have you tried unplugging the oven and then reapplying poqwer afterwards? Manytimes , when elcetronic control logic gets corrupt, a power down/up reset clears the problem. If it continues, I would consider replacing the control board..Here is a link to the circuit board you might consider replacing.. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059895&PPStack=1
These kind of things are generally trial and error and there is no guarantee that this will be the solution to your specific problem..
Hope this helps...
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
