Question about Nikon Coolpix 5700 Digital Camera
How do I stop the 'C1' appearing when the camera is turned on
I have to wait, sometimes up to 50 or 60 seconds before operating the camera
My Cooker is coming up with a E3 What do this means or how to fix it?
Error Code Error Solution
F0 An internal error was detected. Disconnect power. Wait 5 seconds before reconnecting power. If the symbol appears again, call for service.
F2 The surface cooking area is too hot and has turned off. Remove the pans from the surface cooking area. "F2" will disappear when the surface cooking area has cooled. If you turn the surface cooking area back on and "F2" reappears, the cooktop is still too hot. Turn off the surface cooking area and allow it to cool.
F4 The pot or pan is too close to the control panel. Make sure the pot or pan is centered on the surface cooking area and nothing hot is on the touch control panel. Wait 5 minutes for the control panel to clear. If "F4" appears after turning the surface cooking area back on, call for service.
F8 The surface cooking area has been in operation too long. The surface cooking area automatic shutoff was activated. Turn off the surface cooking area.
C1 The power voltage is too low. Turn off the cooktop. Wait 5 seconds, then turn it back on. If this continues, contact a qualified electrician.
C2/C3 The cooking surface area has overheated. The surface cooking area automatic shutoff was activated. Wait 5 minutes for it to cool, and then turn it back on.
Jan 26, 2017 | Washing Machines
Ipod disabled
Like all electronic devices, iPods sometimes freeze and become unresponsive.
Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working.
All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated.
An iPod will appear frozen and unresponsive if this feature is activated.
A lock symbol will appear on your iPod's screen if it is in Hold mode.
Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button.
Press both buttons at the same time and hold them for up to 8 seconds.
Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen.
Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod.
Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it.
Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons.
Connect your iPod to its powerblock or a computer if it is still frozen.
Wait 5 minutes and then try to reset it.
Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
May 15, 2013 | Audio Players & Recorders
2nd gen ipod shuffle non-responsive
Step 1:
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
Feb 19, 2013 | Apple iPod shuffle Second Gen. Silver (1...
SECURITY CODE MODEL NO A1137
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
When connected to the computer the disk does not appear on th edesktop, how to initialize the camera?
Hello.Please try this.With the camera turned off make the connections.Turn the camera on.Wait a few seconds to see if a new hardware message appears.If it does wait till the message says your new hardware is ready to use.Wait a few seconds to see if a window opens asking you what you want to do,(open folder,get pictures,etc.)If so make your choice and proceed. If you don't see this window click My Computer look to see if your camera shows up in the Other Devices list if so open it and your pictures should be accessable. If none of this works try shutting your computer down make all the connections turn your camera on and start the computer. If your problem continues post back in the comments box .
builderdale
Jan 17, 2010 | Konica Minolta DiMAGE X1 Digital Camera
Lost instructions. How do you change value of tax
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
Hope that helps
Dec 23, 2009 | Casio MS-80TV Scientific Calculator
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Is there anyway to resolve shutter lag on the Nikon Coolpix 8700?
oh what mode is your camera in? auto- adjust your Iso it is too bright or dark for your current setting
c1-(manual) change your f-stop and Iso. set the iso to 200 and move the F-stop to any number and test the speed.
c2-same as c1
If you need further clarification write back i'd love to help!
Jan 12, 2009 | Nikon Coolpix 8700 Digital Camera
Need for help.
C1-00 means MC unit malfunction. Try turning the copier off. Wait 30 seconds and turn it back on again and see if goes away.
If it comes back you should contact a technician in your area.
Jul 17, 2008 | Sharp AR-507 Copier
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
