Comfort-Aire BHD-501 Dehumidifier Logo
A
Anonymous Posted on Jun 04, 2014
How do I connect my dehumidifier with a hose directly to a drain
Dan Clancy
Level 2:
Novelist:
Scholar:
  • Expert 109 Answers
  • Posted on Jan 22, 2015
Dan Clancy
Expert
Level 2:
Novelist:
Scholar:
Answers
109
Questions
0
Helped
28016
Points
221
Are you much of a handyman? Most folks set their dehumidifier on a counter or elevated and run the exhaust tubing right into a sink or toilet. You could collect the water to flush a toilet or water the grass if you are handy. I've never seen anyone connect directly to a drain though.
Whirlpool AD50USS Dehumidifier WILL NOT DRAIN THROUGH HOSE
I have a similar model. There are two drains, one for the hose and one directly into the bucket. The hose one is supposed to be lower, but I had to put a 3/8 inch block under the right side of the unit to get the water to favor the hose instead of the bucket. Another possibility is that the far end of the hose is higher than the near end. If you can't lower it, you can put the whole dehumidifier up on blocks. One other thing to check is that the hose has a rubber washer in it where it connects to the unit. Use a tissue to see if this connection is dry. If it leaks, it will just drip into the bucket.
I tried to drain direct via garden hose, perfectaire PA50 dehumidifier. I unplugged the plug, connected the little hose that came with the thing..connected to the inner spout and to the hose adaptor,...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
1helpful
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Hope this helped you.
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
1helpful
My direct drain doesn't work anymore
I fixed the same problem, finally. At first it was sufficient to clean the outside hose (it was filled with a **** builtup). Then it stopped working again. I decided to open the unit and see how easy it is to clean the inside drain hose. It is very easy. Once you unscrew the back panel (8 screws total if i remember correctly) you can access the back and you see the drain hose that connects to the drain outlet. To remove it and clean it, you will have to unfasten the big capacitor (3 screws). Then, remove the hose and clean it (mine was full of that same **** stuff). Reinstall - you will need a tie wrap to connect the hose at the top, as it is from the factory. Very easy operation and now the dehumidifier is draining again.
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
Top Comfort-Aire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
