for web cam to work you neeed the webcam drivers you can download the drivers from the net first you have to connect the webcam and check wether the cam is working all the sites accepect any type of cam to downlad the cam drivers you need to go to www.google.com adn tyepe the name and model no in the search then you will see the list of drivers or you can go to the company site and download the drivers by entering the model no
I'm assuming that by you saying the DS lite has gone dead that you get no green light at all. If this is the case then chances are you have blown the F2 fuse, this is an internal fuse and measures less than 2mm on its longest length.
I would suggest sending the unit off if you have a warrantly, or tking it to a local repair shop/ service...
You can replace the fuse yourself if you wish... This will require specialist tools as well as having good soldering skills.
If you would like some further information about how to replace the fuse and what tools you will need then click on my name and have a look at some of the guides i have written.
I am not sure what you mean by the "AV program". I am going to take a guess that you mean the video input channel. Well with monitors they really do not have those.
If you can let me know the exact model of monitor you have an can double check your connections and setting for you.
Now since you have a PS3 the best connection for you to be using is the DVI port on the monitor. Now since most monitors do not have an HDMI port you will neeed to get a HDMI to DVI cable.
Let me know if this is how you have it connected and are still having trouble getting the monitor to work.
if you find the fuse blown, replace it mini fuse type 250volt 3ampre. and once you replace and it blown again. there have a problem of your audio I.C output. this are shorted.. and of course you buy it to an electronics store...
