How can I download only most recent pictures that have not been downloaded???
It depends on what software you are using to transfer photos from the camera to your computer.
If you install and use the "Camera Window" transfer software Canon included with the camera, you will see you have three modes to choose from, including the option to transfer just the photos on your camera that have not yet been transferred.
Connect the camera with a USB cable to your computer.
Power up the camera.
The computer will detect the camera, and open a dialog box offering you a choice of programs on your computer that can handle photo transfers.
If you choose the Camera Window software, it will open and present a menu with three choices of action. The first option is, "Import images from Camera." Select this.
Another submenu opens presenting these three options:
1. Import Untransferred images. (this is what you said you want)
2. Select images to Import. (manually select just certain ones)
3. Import All images (automatically transfers every image on the card)
Menu screenshot, Canon's "Camera Window" transfer software
Camera Window is just one of many available image transfer applications you could use. They all do essentially the same three things outlined above, including "Import Untransferred images."
Canon included a couple other utility programs on the CD that came with your Powershot A490 camera. One of them, "Zoom Broswer EX" enables you to reload photos from your computer, back on to your camera's image card, if you want to do that.
SOURCE: Unable to download pictures from canon A530 digital camera
Try removing the memory card and inserting it again.
Also, does the computer detect the camera properly?
SOURCE: Program Zoom browser won't download pictures from the camera.
Uninstall and reinstall the Zoombrowser. It looks like a driver or something with the program is corrupt. But, first read on before doing anything.
But, before doing the above, check the software and camera configuration. Also check to see that there are no other active programs running in the computer that may be taking presidence over the Canon software and accessing control of the camera's port, thus blocking Canon's software from being able to read the camera.
You can try calling Canon's tech support and ask the question. They will know their product the best.
Microdrive:
A microdrive can fail much easier than a solid state memory card. I have had them fail. Mircodrives are fairly fragile compared to memory cards. Microdrives are mechanical devices. The new generation of memory cards are excellent.
I have an old digital camera with an IBM 1 GB microdrive. The present drive still works! It was terribly expensive when I bought it about 4 years ago. I am now using a 2 GB solid state memory card. I found it to be superior to the old microdrive.
Jerry G.
