Check linkage on your carb or throttle body. Check the outermost cable connected to linkage. That is cruise control cable. Follow cable to cruise control box. usually mounted under drivers side fender. You may have to remove fender splash sheild to access. Cable end at carb linkage either pops off or move end forward while holding linkage still & it should come off. On cable end, there is a round hole & smaller diameter slot which holds cable end from coming off the linkage pin. Cable box under fender usually has electric plug. Remove this & unbolt box from fender. Replace new unit in reverse. Before buying new CC box & cable. Check to make sure buttons on stearing wheel are making contact to cruise control box.
