With the composite video (yellow) connector, the VCR and DVD functions both work, but in black and white only. With the red, green, blue connectors, DVDs play in color, but videos won't play at all. When I change the source on the VCR/DVD player from DVD to VCR, the DVD continues to play, even through there is a video inserted and it is playing.
SOURCE: How to hook up a DVD player
are you conecting video out/dvd to video in/tv and select av on tv.simple. reg'chook.
SOURCE: Hooking up a DVD Player with NO remote
Some TV's will let you access inputs by going through the channels to the very end and see if it works.
SOURCE: RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
SOURCE: RCA Colortrak Stereo Monitor won't play DVD/Nintendo
The way you describe having your TV/DVD connected you wont see the picture in the regular channel line-up.
You will have to tell the TV to to switch to the video input. This is usually done by navigating the menu to the "input" and selecting video 1, video 2 etc
Failing that try changing to channel 00 ( just type 00 in remote)
Some sets will allow you to type in 02 and then hit the channel down button on the remote.
If you have the user manual it will give you the exact steps you need to take.
SOURCE: RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
