HOW MUCH WOULD IT COST TO HAVE A FUEL PUMP INSTALED
George,
No simple diagram for changing the fuel pump. It is located inside the gas tank. The gas tank needs to be removed to change the pump. The pump is part of an assembly which consists of the pump, fuel gauge sender and pick up. You also need to change the fuel filter when you change the pump. It should take a professional mechanic about 3 hours to drain the fuel out of the tank, remove the tank, change the pump and fuel filter. Multiple the mechanic's time by whatever the repair shop charges per hour for labor. There are several different pump assemblies for the vehicle. Price depends on whether it's 2 or 4 doors and 2 or 4 wheel drive. Best guess is about $600 total.
