Whirlpool AD50USS Dehumidifier Logo
A
Anonymous Posted on Jun 03, 2014
Filter removal instructions for whirlpool dehumidifier
Cant get the filter out
There is ice on the filter and the filter will not come out. Tried turning off so it would melt, but filter still stuck. It is summer so why is ice forming?
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I had mine ice up once or twice particularly on very high humidity days > 90%. Once it thawed out. I was able to remove the filter. Most likely it is due to dust getting on coils & condenser Or actually has a Freon leak. to resolve the dirty coils you can easily dissemble (that is remove front & rear cover) it to give coils and condenser a good thorough cleaning. It the coils and condenser are not at all dirty, then is not the cause of the icing. The units are typically not serviceable - i.e. a disposable small appliance.
Where is the filter on this dehumidifier. Mod# ad75ust
To locate the filter: Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
My dehumidifer runs but no water is being pulled out
Might be a dirty coil and condenser.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
The dehumidifier I have is a model AD40LBK Whirlpool. How do I clean the filter on this model.
The filter will e in one of two locations;
1. Remove the water bucket and look up just inside the bucket holder for a pull tab type handle. If you see one or two, that is the filter frame. Pull staring down on it. If you have never removed the filter before thee may be a piece of tape holding it up in place. This was just for shipping purposes. Remove the tape and discard it.
2. On the right hand side of the unit (as you face it) there may be a rectangular flip open plastic door. Behind that door lies the filter. Open the door and pull the filter straight out. Like the above, it may have a piece of tape on it. Remove the tape and discard it.
To clean the filter. you can vacuum ti using a vacuum that has a hose & brush attachment. If it is really dirty, wash it in warm water and mild dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter installed. Doing so, can damage the unit.
I hope this was of help to you and thanks for choosing FixYa.
2helpful
Only the fan is running Thanks. Douglas Bisson..
Mr Bisson, there are several things that can casue the problem you have. All of which a usually solved very easily.
1. Dirty or clogged air intake filter. Remove and clean the filter per the manufacturer's instructions. Clean the filter once every two weeks, as part of routine maintenance.
2. The humidity extraction level is set to HIGH. Lower the setting to 35% or lower.
3. Obstructed air flow. Maintain a minimum of 12" clear air space on all sides of the unit, while in operation.
Any or all of the above can cause the problem and are easily solved. I hope this helps to troubleshoot the unit and solve the problem..
1helpful
2answers
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
7helpful
I need to know how to clean filter. Lost book
follow the below instructions:
Turn off the dehumidifier machine and unplug it from the wall.
Lift the water bucket up and out of the dehumidifier.
Locate the filter located under the compartment that houses the water bucket. Lift the filter straight up and out of the dehumidifier.
Vacuum as much of the visible dirt and debris as possible.
Fill a sink half full with water. Place the filter in the water and allow it to soak for one to two minutes.
Wipe both sides of the filter with a wet sponge to remove any remaining dirt and debris. Rinse the filter with clean water.
Wipe the filter with a dry cloth to remove excess moisture. Allow it to air dry for approximately 30 minutes before inserting it back into the dehumidifier.
Good luck.
Whirlpool dehumidifiers
If the filter is dirty it can block air flow. Try washing it if it's removable.
Top Whirlpool Dehumidifiers Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
