Accutron Swiss Watch by Bulova 26B44 Logo
A
Anonymous Posted on Jun 02, 2014
Value/ year made
Value/year made
jayarambro
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Oct 21, 2019
jayarambro
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
980
Points
7
Excellent Blog! I would like to thank for the efforts you have made in writing this post. I am hoping the same best work from you in the future as well.
I wanted to thank you for this websites! Thanks for sharing. Great websites!
gbwa
Terrence MacArthur
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 06, 2014
Terrence MacArthur
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
2263
Points
10
The year made cannot be determined from the SN. Since the '50s Bulova used a 2 character date code, usually below the SN. The letter is the decade, the number is the year. For example, M4 is 1964, N6 is 1976, O5 is 1985, etc. As to value, if it is from 1960 through 1976 (M0 thru N6) it is a "true" Accutron, with a tuning fork movement, is collecrible and valuable, and the actual value depends on which specific movement and which case. Some 1977 (N7) Accutrons are akso collectible rtuning fork watches, but some 1977s are Bulova's first quartz watches, and of no value. Bulova eventually went mostly automatic (self-winding mechanical movement) with their Accutron line. Those are well-made, mid to upper-mid level watches, and of no particular value beyond that of most any good used automatic. Note, however, that there have been numerous versions of the automatic Accutrons, some fancier and nmore expensive than others, and, s ith any good watch, original cost will have an effect on value as a used watch. For example, that retailed at, say, $500 new in 2009 will be worth more today than one that was $250 new in 2009 (assuming comparable condition). There are also now some Accutron IIs, which mimic, in looks and the sweep second hand, the original tuning fork Accutrons. However, while they are well-made watches, they are just another nice quartz watch.
The value and year it was made
See: http://elginpocketwatch.net/elgin-pocket-watch-value/
Whats the value of bulova watch c9671206 ?
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
I just bought a watch its number is ADH4017 i believe its the peach tree watch,something like that. its neon yellow, anyway i cant find the settings to change the time. can somebody please help me i...
TIME/CALENDAR SETTING
1. In normal time display, press and hold A to enter setting mode; chime will begin
flashing.
2. Press C to increase setting value. Press D to decrease setting value.
3. Press B to set and advance to next setting value.
4. Setting sequence is chime, 12/24-hour time, hour, minute, second, year, month,
date, Auto EL.
5. Press A to save data and exit setting mode.
Elgin pocket watch value
RECOMENDATION:
Find a registered repair person in your area. It is very difficult if not impossible to find a value on you watch via the Internet sight unseen.
GOTO:
http://www.watch-clock-makers.org/
MORE INFO ON YOUR WATCH:
Total production: 159000
Finish: Gilded
Approx year of production: 1894
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
1helpful
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
4helpful
3answers
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
9helpful
3answers
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Top Accutron Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Accutron Watch Expert? Answer questions, earn points and help others
