The latest driver provided by Cisco systems for the PI21AG PCI 802.11a/g adapter was for Windows Vista (Version 1.1A). Currently no Windows 7 driver is listed in the downloads in the software center on Cisco.com. Windows XP and 2000 Drivers are also available (WinXP install wizard is 4.5). Sometimes the Windows Vista or Windows XP drivers can be used in Windows 7 and you may try that. Driver downloads can be found at https://software.cisco.com/download/type.html?mdfid=278853379&flowid=7244&sc=Y&softwareid=280775081
1) download a copy of the k9 installer and have a license key ready2) open task manager (CTRL+Shift+ESC) and under processes End Process on K9filter.exe3) go to your program files folder and locate the Bluecoat K9 installation4) create a new folder called backup within the above folder5) Click Tools> Folder Options > View > and Show Hidden files6) Copy contents of K9 folder into the new backup folder7) go to start > run > type regedit (Windows vista or 7 go to start and type regedit in the search bar)8) Navigate to HKEY_LOCAL_MACHINE\Software\Blue Coat Systems9) rename K9 folder to something like OLDK9 (anything but K9)10) Open IE and go to http://www.google.com11) Set Your Password12) Now uninstall the software
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website
2.Click "get K9 NOW" tab on the top-left
3.Fill out the information and your email.
4.Download the K9 Web protection software from the link included in the email and keep a copy of the license.
5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job.
6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab.
7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection.
8.Remove the contents of the folder but not the folder.
9.Run the K9 web protection setup/installer file which has the same version as the one you just delete
10.Provide the license and create your new password
11.Point the installation folder to the same folder you just empty the contents earlier on
12.Now you can have a re-installed K9 web protection with a password you know.
How do you uninstall K9 web protection now? Use the new password you just created
If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode"
Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder)
Click "Start"->"Run" and type "msconfig"
Check the tab "Services" and tab "Startup"
Un-check anything that is related to k9
If somehow this method is messed up, try to download K9 again to at least restore your previous installation.
If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
You Have k9 installed and it is blocking your acess to your router page here's how to disable it
To disable K9 Web Protection, follow these steps:
1. Download the K9 Web Protection Installer for your system (64bit, or 32bit)
2. Let it download, and instead of clicking "Run" Click "Save" and save it to a location of your choosing.
3. Right click your "My Computer" icon, then click "Properties". When that window opens up click on the "Hardware" tab, then click "Device Manager" when the next window opens.
4. Click the "View" tab at the top of the Device Manager, then click "Show Hidden Devices".
5. Then look for "Non-Plug and Play Drivers" and open up that tree. Then find the device called, "bckd". Right click it, and then click "Disable"
6. A message will pop up telling you to reboot your PC, do so.
7.
After it boots up, there should be a message down in the right corner
saying "K9 Web Protection has become Corrupted" or something similar.
This is good :).
8. Before you can surf the internet, go to wherever you saved the K9 Installer from steps 1 and 2, and run the installer.
9.
It should just pop up with a message asking you to update K9 web
protection, click "Yes" and for the next message that pops up, click
"Ok"
10. Wait a little bit, and then you can go to any Website and acess your router page
11. To re-enable K9 Web Protection, just go back to the device manager and re-enable "bckd".
Click the Windows "Start" menu and click the "Control Panel. Double-click "Add or Remove Programs" to launch the programs list if you are using Windows XP. For Windows Vista and 7 users, launch the programs list by clicking "Programs" and clicking "Programs and Features." Scroll down and click "K9 Web Filter." Click "Remove/Uninstall." Click "Continue" on the Uninstall dialog box. Select "Yes" to uninstall K9 Web Protection. Type your K9 password and complete the uninstall. When prompted, restart your computer.
I found this on superuser link at the bottom. No third party software required. Tested with K9 Web Protection version 4.4.268 on Windows Vista SP2 (32-bit). Confirmed by @stiemannkj1 to be working on Windows 7. Should also work on Windows 8.x.
Create a new text file. Copy and paste the following batch script code, then save:@echo off set keys=^ "HKLM\SOFTWARE\Blue Coat Systems"^ "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\k9filter.exe"^ "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Blue Coat K9 Web Protection"^ "HKLM\SYSTEM\CurrentControlSet\Services\bckd"^ "HKLM\SYSTEM\CurrentControlSet\Services\bckwfs" REM remove registry keys for %%G in (%keys%) do reg delete "%%~G" /f >nul set folders=^ "%programfiles%\Blue Coat K9 Web Protection"^ "%programdata%\Microsoft\Windows\Start Menu\Programs\Blue Coat K9 Web Protection" REM remove folders for %%G in (%folders%) do rd /s /q "%%~G" set files=^ "%windir%\System32\drivers\bckd.sys" REM remove files for %%G in (%files%) do del "%%~G" pause exit /b
Right-click the .cmd file and select Run as administrator from the context menu. Wait for the batch script to finish.
Start regedit.exe and navigate to the following registry key:
<code>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_BCKD
Right-click the LEGACY_BCKD key and select Permissions from the context menu. Click Advanced and select the Owner tab. Then select Administrators from the owner list, tick the Replace owner on subcontainers and objects option, and then click OK. Then select Everyone and tick the Allow checkbox for the Full Control permission. Click OK, right-click the key and finally choose Delete.
Disable the Bluecoat service from the Windows Service Control Manager. Remove the file bckd.sys under Windows system32 drivers directory. Reboot the box.
