Update Z77M-D3H BIOS NEW
SOURCE: BIOS is more than two years old.
Hi karl, please click on the link provided below.
http://www.asrock.com/mb/download.asp?Model=P4i45D%20R3.0&s=
Scroll to the bottom of the page. These two bios updates are the last updates posted by Asrock. All drivers are free.
Asrock's main web link for the P4i45D motherboard.
http://www.asrock.com/mb/overview.asp?Model=P4i45D%20R3.0&s=
If you find this information answered you're posted question, please vote this as a fix.
Have more questions, feel free to post it here or click the Ask Me button under my user ID.
Mike
SOURCE: how install new bios
new bios is very difficult to change and it cant be updated easily. i suggest you purchase new updated mother board for your system.
SOURCE: MS8157E BIOS update
http://www.bios-drivers.com/drivers/182/182756.htm
try this. I dont know the date that you have the date info on the card and see if that website works.
SOURCE: Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
