SOURCE: HP color laser jet printer is displaying error
The "developing disengaging motor" has problems. You need a technician. Try running the component test from the control panel. Select the disengaging motor and test it. Maybe it'll start working after the test!
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
SOURCE: hp 5550 color laser jet
Check the following link..........
http://www.fixya.com/support/t1517115-error_code_59_c0_in_hplaserjet
SOURCE: HP Color LaserJet CP1515n Printer is showing error
error 51.23 on the hp color laserjet cp1515n printer. please help
