SOURCE: reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
SOURCE: will iP-tool.exe v.1.1.5 reset my iP2600 ink levels to 100%
Yes it does reset ink levelsas well as do several other things very well.....highly recomend the program for an ip2600
SOURCE: canon ip2600 reset problem
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
