Question about GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool mhe14xmq 0 everything works except FOR HEATING
Everything works except FOR HEATING
  • Official Brand Answer
  • 408 Answers
Hi, Consumer. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Posted on Jun 06, 2014
2 Suggested Answers
Anonymous
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Whirlpool GH7155XKQ, everything works except it is not heating.
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 24, 2009
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Everything works except it will not heat.
I had the same problem. I just got a new one to heat my heating pads. Microwavable Heating Pads
Jan 27, 2015 | Whirlpool GH7208XR Convection / Microwave...
Not heating
Usually one of three things and not in any order:
The diode commonly used in most microwaves= it cannot be shorted and work.
The inverter board which powers the Magnetron.
The magnetron itself which does the work and can only be tested for sure by replacing.
12_12_2012_1_10_05_am.jpgtypical Microwave diode.
12_12_2012_1_10_45_am.jpgtypical Magnetron
Dec 11, 2012 | Sharp Microwave Ovens
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
Oct 08, 2010 | LG LMV1680ST Microwave Oven
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
Jul 07, 2010 | General Electric Microwave Oven
Microwave stopped heating up the food. Everything works except for the heating mechanism.
Check the door safety interlock switches. Remove the cover to find these small micro switches on the side away from the hinges.
Need more help ... post a comment here
thanks for using FixYa.com
Nov 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave is not cooking/heating.
sounds like the magnatron they can just go out like a light bulb easier to buy a new microwave hope this helps regards Jim
Apr 13, 2009 | Microwave Ovens
Microwave is not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fs
Mar 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
