Computers & Internet Logo
I
Iraj Nejad Posted on Jun 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The usb drive doesnot open windows need to format
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,226 Answers
  • Posted on Jun 12, 2014
James Miller
Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447434
Points
2985
Make sure that your usb drive is installed first then try it again or try a friends computer ok
Jachary1
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 04, 2014
Jachary1
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2441
Points
22
We need a bit more information here. Was this a new usb ? If so you may simply need to format it in windows (a quick format would do using FAT32). If this is an usb with data on it was it used by a windows or linux os ? If windows was it NTFS?
  • 2 more comments
  • Iraj Nejad
    Iraj Nejad Jun 04, 2014
    Dear Jachary
  • Iraj Nejad
    Thank you for your kind reply, the USB was carrying my documents, i used it in a office in other country and i am not sure about their windows was it NTFS or FAT32 also the information inside is very important so i can't format it. It is big problem for me now. Anyway thank you again
  • Jachary1 Jun 04, 2014
    Wellyou may want to mount it on a unix system and see if you can read it. If you dont have that option you can try Wondershare Datarecovery, there are freeware ones out there but I would say try Wondershares.
  • Iraj Nejad
    I do my best and inform you thanx again
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 • Computers & Internet
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
1helpful
My usb can' formate and open
Try formatting it using windows explorer. if the drive where your flash drive is plugged is recognized by windows explorer and the drivers have been installed but if not perhaps your flash drive is defective and need to be replaced..
2answers
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
I have problem with my hard drive can not open, when i put in computer it doesnot show on .
it seems its not formatted - if you have Windows, try this:
Start > control panel. Then Go to Administration Tools (or somethine like that, dont have windows in english) and find Computer Management icon. Run it. Now explore to Disc management - there you will see your USB HDD. Click on them with right mouse button and create new partition, etc..
1helpful
I need a program to format the flash device
put your USB drive in open windows explorer my computer you should see your drive right click select format
Device not working/screen shows installation driver problem
You can try to format the disk NTFS File system.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format NTFS files system.
hope this help you
Regards
uttam
Usb 1GB don't format
try to format it in another computer, see if it works over there or not. if not then its the time to buy a new one.
4helpful
2answers
I want to install driver of jf v30/1gb on my system
I formats the pen drive but due to the electricity cut off, format doesn't complete and pen drive doesn't recognize in computer
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
