How do I remove the remove back off my bulova mens self winding watch case # F823550
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
SOURCE: Bulova Men's Marine Star Alarm Watch 98A000
if its a cronograph they can be complcated but in most major cities look for a place called battries and bands or precision time bothe are the same company and have a web sight. if you find a close location the people will be happy to help you and they do realy good work for a resonable price.
SOURCE: Bulova Millennia Vibra Alarm Mens Watch 98A48
The manuals are available from Bulovas' website www.bulova.com
SOURCE: I have a Bulova Caravelle
Hi. If you take a tiny screwdriver (one that you might use to screw a screw into an eyeglass and run it gently around the back you will feel an indentation where you can insert the tip and pop open the back. The battery is easy to access but trying to get the back back on is the problem! Good Luck.
SOURCE: I can't seem to remove
If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
