Televison & Video Logo
Haleem Rahman Posted on Jun 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi im using samsung smart tv model UA40EH5306. The remote control seem to go haywire. When i press the volume button it just change the channel. Every button pressed changed the channel. Pls help
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Jun 02, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986539
Points
237762
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops or online by Alibaba.com. Never trust Ebay. I'm a victim of their cheat.
5 Related Answers
Anonymous
  • Posted on Jan 26, 2008
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
dinomb
dinomb
  • 16 Answers
  • Posted on May 11, 2008
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Anonymous
  • Posted on Mar 30, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Anonymous
  • 102 Answers
  • Posted on Sep 20, 2009
SOURCE: Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code. There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
Anonymous
  • Posted on Feb 22, 2010
SOURCE: alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Testimonial: "Excellent! It works, many thanks for your help"
Can I turn off my 55 inch Samsung tv without using my Comcast control? My Comcast control does not work.
Hope this helps.
What is Jog Controller in Samsung TV's ? Last Update date : 2016.11.11
The Jog Controlfeature is a quick and easy way to enable and access certain functions and features on yourSamsung TV without a remote control. Television now use a Jog control instead of touch buttons to control the TV without the remote control. This control is located on the rear or bottom right side of the TV and will feel like a little joystick. Move the Jog conroller towards the icons indicated on the all four sides to control channel and volume. Press and hold the Jog controller to turn off the TV.
Here are some description of Jog Controller :
Channel Up : Changes the channel upward.
Channel Down : Changes the channel downward.
Volume Up : Increases the volume level.
Volume Down : Decreases the volume level.
Display on the bottom right of the TV screen opens by pressing Jog Controller once :
Smart Hub : Opens up Smart Hub.
Return : Brings back to the TV viewing.
Source : Changes the source.
Power Off : Turns TV off.
Menu : Opens up the TV Menu.
Related Model Information PS43E400U1R, PS43E470A1R, PS43E490B3R, PS43F4100AR, PS43F4900AR, PS51E470A1R, PS51E490B3R, PS51E550D1R, PS51E8000GR, PS51F4900AR, PS51F5500AR, PS51F8500AR, PS64E8000GR, PS64F8500AR, UA22ES4003R, UA22ES5000R, UA22ES5005R, UA22ES5100R, UA22F5000AR, UA22F5100AR, UA23F4002AR, UA23F4003AR, UA26EH4000R, UA26EH4800R, UA28F4000AR, UA28F4100AR, UA32EH4000R, UA32EH4003R, UA32EH4500R, UA32EH4800R, UA32EH5000R, UA32EH5330R, UA32EH6030R, UA32ES5600R, UA32ES6200R, UA32F4000AR, UA32F4100AR, UA32F4500AR, UA32F4800AR, UA32F5100AR, UA32F5500AR, UA32F6100AR, UA32F6400AR, UA39EH5003R, UA40EH5000R, UA40EH5330R, UA40EH6030R, UA40ES5600R, UA40ES6200R, UA40ES6600R, UA40ES6800R, UA40F5000AR, UA40F5100AR, UA40F5500AR, UA40F6100AR, UA40F6400AR, UA40F6800AR, UA40F7500BR, UA46EH5000R, UA46EH6030R, UA46ES5600R, UA46ES6200R, UA46ES6600R, UA46ES6800R, UA46ES7500R, UA46ES8000R, UA46F5100AR, UA46F5500AR, UA46F6100AR, UA46F6400AR, UA46F6800AR, UA46F7500BR, UA46F8000AR, UA50F6800AR, UA55ES6200R, UA55ES6800R, UA55ES8000R, UA55F6400AR, UA55F7500BR, UA55F8000AR, UA55F9000AR, UA60ES8000R, UA60F6400AR, UA65ES8000R, UA65F8000AR, UA65F9000AR, UA75ES9000R, UA75F6400AR, UN26EH4000M
2helpful
2answers
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
7helpful
2answers
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
44helpful
5answers
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
4helpful
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
3helpful
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
1helpful
2answers
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
