SOURCE: Ilo-32HD
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
SOURCE: ilo-32hd
the problem is the control board try here http://www.shopjimmy.com/ its an easy fix and a common problem in these sets good luck
SOURCE: ILO 32HD LCD
This is pammy0
Mine was sent to lifetime service center in williamsville ny. Is now working fine. the part number that was replaced is 3 31-5465 description is 1200UF 16V CAP. Hope this can help ya out. I also have there phone number 1 800-447-0092 or 716-632-0216. I dont know what this cost to be fixed cause i had a extended warranty that i bought threw walmart.
SOURCE: ILO-32HD
i have the same problem too. got a number at Walmart and ask to call this number directly: Intial Tech Corporate office: 909-392-5583
SOURCE: ILO-32HD
This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
