in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
SOURCE: Error code on my waterco titanium pool water heater says nFL.
NFL code: No water flow, not sufficient water flow through the pool heat pump or the water pressure switch needs to be adjusted or is defective.
