(1) Make sure that the fan is turning OK as dust often gums-up the bearings. (2) Make sure that the heat exchangers are not clogged with dust. If the main motor, the so-called pot, is running but no cooling results it could be
(A) The refrigerant has been lost. This is an extremely bad fault which makes the unit a basket-case. The reason being that even if a self-piercing filling point is added to recharge the unit with refrigerant, unless the leak is found and fixed the repair will be a nine day wonder.
(B) This fault is more likely and the fix is do-able. It is quite likely that the machine is stuck in its defrost cycle. Wiring problems, thermistor problems or relay problems are all possibilities. Some machines use an electric heater on the evaporator (the part that freezes-out moisture from the air) If the heater is stuck on, the evaporator will never become cold enough to work. The more usual defrosting method is Hot Gas Purge and if this is the type used there will be a special electrically operated valve in the refrigeration circuit. Often the default is to defrost-on-start-up so its easy to listen to the valve to see whether it clicks. Good luck!
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable. \ Hope this helped you. Please let me know. Thanks.
If the unit is freezing up I suggest replacing the sensor assembly. Just replaced mine because the thermistor that is on the suction line went bad and would not send the reversing valve into defrost.
