Thermador SMW272 Electric Double Oven Logo
A
Anonymous Posted on Jun 01, 2014
How much do it cost? - Thermador SMW272 Electric Double Oven
2answers
Why won't the broiler turn off?
Hello Cathy;
My name is Peter. I am a retired field service appliance technician.
I am afraid I have bad news for you. This is an expensive repair. I am sure it is not your thermostat. I wish it was that simple.
If you have to turn off the main breaker to shut off power to your unit, there are only two components that control where the power goes to your unit.
1.) Electric Built-in Oven Black Membrane Switch
Note how close on the lower left how close the select buttons for both the, "Bake" and "Broil" are.
25695417-guxvworl0v2zgxzjtpf0vne4-4-0.jpg Part Substitution: 8304266 Cost: $172.00
This component is connecter directly to:
2.) Range Electronic Oven Control Board Part #: 8303885 Cost: $220.00
25695417-guxvworl0v2zgxzjtpf0vne4-4-2.jpg The cost is based on Sears parts. You can purchase them over the internet for slightly less.
Only one of these parts is bad. I can not tell you which one without my physically disassembling and testing them.
If I were still working for Sears Home Services or A & E Factory Services and I came to your home. The service call cost would be the part cost X 2, or lets say $220.00 x 2 = $440.00 plus about $200.00 labor, or a bill of $640.00.
The rule of thumb is; " If the cost of repair is 1/3 or more of the original purchase price, buy new".
May I suggest, you go into the internet and search, "Sears Outlet Store". This is a scratch and dent store. You can save hundreds of dollars on a new oven. You also receive a one year warrantee on the appliance.
I wish I could have been more help to you.
Peter,
Glen Burnie, MD
Ms. Cortes bought 20 blouses for P2,400 and marked them to sell at P145 each. After selling 16 pieces at this rate, She decided to sell the remaining blouses at a lower price. at what price may she sell...
total cost of blouses p2400
16 sold at p145 = 2320p
p2400 - p2320 = 80p loss on original stock cost
to make a p480 total profit p480 + 80p(cover loss) = 560P
560P /4 = 140p
560p +2320 p = 2880 ptotal proceeds
profit = proceeds - original stock cost
profit = 2880p - 2400p
profit = 480p
Answer is 140p
3helpful
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Grill not working at all. How much will this cost to repair
Obviously, it depends on what the fault is but on the assumption that you need a new element, anywhere between £60 and £120. I'd charge about £70 as I only charge cost price on parts. Many appliance engineers have a standard mark-up on the price of the parts, which can be anywhere between 20% and 100% if they think they can get away with it.
If you are able to repair it yourself the cost will be simply for the part plus delivery - about £35.
My charge would be the true cost of the part (£35), 1 hour labour (£15), VAT, and I'd add £10 for call out and fault diagnosis. Total £70.50.
Hope this helps.
The oven door has come off and i think the springs have to how much will this cost or can i do it my self
There are many brands and models and the costs will vary. Most require removing the sides of the oven to get to the hinges and springs.
Feb 28, 2010 • Ovens
Oven wont lite. top pilots all ignite
oven ifnitor has failed / remove bottom of oven to replace. not a hard job.. ignitor cost 49 to 70.00 depending on model best to use a maytag flat style . this will cost you less.. mm hope this will help you mm
Door does not seal, hinge looks fractured. the door looks like it has dropped and does not seal at the top, also when lowing the door there is no resistance and it wants to just flop down. Both hinges look...
you'll probably need to replace the whole door and hinges. the internal springs (inside the door) may have failed and allowed the door to drop and damage the hinges. don't believe it's fixable, but is replaceable.
at what cost, i can't guess- even if the parts are still available! compare the cost of fixing to the cost of replacing!
good luck!
Oct 04, 2009 • Ovens
I have a Kenmore Elite slide in electric range and the oven will not preheat to temperature (even after 40 min.) The repair man says I need a new control panel that will cost me almost 500 bucks...Any...
Hi. the electronic oven control board actually costs 198.00 but, the labor charges will inflate the cost because of the need to disassemble and add new wire harnesses. On most models, this relay is separate from the actual control board and it is usually linked via, wires. I would check around to see if you could get a second and maybe a third opinion. In my experience, you should just be able to replace the temp sensor or relay and that should fix the issue. Normally, if the control board is experiencing any issues, you will see a error code of some sort. I would defiantly get a second or third opinion before allowing the service tech to do the repair. that repair cost seems to be highly inflated in my view.
Please rate and god bless:)
Apr 03, 2009 • Ovens
Fan in oven works but only warms the oven
If the element was gone completely then the oven would not heat up at all. If the element blew while the oven was on then that would explain why it was warm. Elements cost between £20-£40, plus any labour costs. You can find this out when you contact the repair shop. Another thing to consider though is that it could be the thermostat, which controls the heat. These cost from around £25 upwards again you would need to confirm this with the repair shop. All in all I think you are looking between £50 - £80 to get it repaired.
Top Thermador Ovens Experts
ZJ Limited
ZJ Limited
vince
john h
Are you a Thermador Oven Expert? Answer questions, earn points and help others
