Microwave Ovens Logo
A
Anonymous Posted on Jun 01, 2014
How to change the fuse Model smh1611s
Will start but not heat anything up
1helpful
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
My door to my Samsung microwave stopped latching. Model number Smh1611s. It still works if you hold the door closed. What parts do I need.
Where the tab broke off drill a small hole about 1/8 in hook spring back close back frame. no new part needed
Oven went dark. changed two glass fuses and everything works but oven doesn't heat anything
A bit more info? BRAND? MODEL? AGE?
Sounds like the Magnetron might done. Checked the Thermal fuse? (should reset)
Samsung model smh1611s no heat
please make this test use the multimeter and fix it.
God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
1helpful
Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Won't heat
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
1helpful
2answers
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
