LG Studioworks 700S 17" CRT Monitor Logo
A
Anonymous Posted on Jun 01, 2014
Which color of vga 15 point 13 & 14 - LG Studioworks 700S 17" CRT Monitor
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
Need code for interex adapter please help Tomas [email protected]
MONITOR RESOLUTION SETTING
12" RGB 512x348 13467
13" RGB 640x480 66Hz 1467
PORTRAIT 640x870 23467
VGA/SVGA 640x480/800x600 60 Hz 2367
15" TILT N/A 2467
16" COLOR 832x624 1367
19" COLOR 1024x768 1267
21" COLOR 1152x870 123467
2 PG MONO 1152x870 3467
NTSC N/A 12467
NTSC/PAL N/A 12367
HI-RES 12-14" up to 640x480 1467
MULTI SCAN 14" up to 832x624 146789
MULTI SCAN 16" up to 1024x768 14679
MULTI SCAN 21" up to 1280x1024 14678
8helpful
2answers
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
8helpful
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
3answers
Projector Cable
Found a pin-out at: http://www.diyaudio.com/forums/diy-projectors/78108-ezpro-550-rgb-cable-pinout.html
1 2
2 5
3 9
4 No conectar
5 14
6 1
7 6
8 13
9 15
10 11
11 no conectar
12 No conectar
13 3
14 12
15 No conectar
You probably need to have a special cable made up.
I just bought a cat5 cable and to covert to vga male and famle head . But i have no clue which pins to solder together because cat5 has 8 cores , while vga has 15 pins or so can you help
I'm not exactly sure how you expect to use a Cat 5 cable for VGA video (Takes 12 wires last time I looked) but here is how the cable connectors are wired
SVGA (35-37 KHz - 800x600) 15 pin sub D:
6
1 Red (Analog) 6 Red Return 11 (ID0) GND (Color) 11. . . 1
2 Green (Analog) 7 Green Return 12 (ID1) NC (Color) . . .
3 Blue (Analog) 8 Blue Return 13 Horzontal Sync . . .
4 Not Used 9 Not used 14 Vertical Sync . . .
5 Ground 10 Ground 15 Not Used . . .
15 10 5
4helpful
2answers
Samtron vga cabal color coding problum
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
34helpful
6answers
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
