It could be the disk have you tried other ones? if the problem persist it could be your ps3 since its new call them up and get another one free of charge
NEWER ONES WONT PLAY PS2 GAMES NO MORE OK,,,TRY TO CLEAN DISK REAL GOOD ,,NEW ONES ARE TOUCHY ..I BOUGHT CALL DUTY 4 WOULDNT WORK USED NO SCRATCHES ON IT AT ALL BUT ONE SMEAR MARK ON IT WONT COME OFF ,,BOUGHT NEW WORKED FINED ,,TRY YOUR FRIENDS GAMES ...
its your lens you can buy one off ebay it kind or alot of work to take apart everything thats what mine did i put new thermol paste on the heat sinks that did not work then i bought a new lens works fine now you tube how to do it all i know nothing on how to fix it youtube has bunch of videos
As long as the movies and games are the actual things and not some burnt rip-off discs you'll be fine. The movie companies do this so their stuff isn't copied illegally.
Merry Christmas!
If this has helped you, please give me a good rating!
It might just be coincidence that your blu-ray drive has packed up at the same time as the update. Ring up Sony and tell them this and you could get a new console for free if your in the warranty.
Hi,This is a common problem on the PS3 unfortunately and is caused by a faulty blue-ray drive. Unit will have to go back to Sony for service.You should try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue. You can also open the case and clean the laser lense with a Q Tip and an alcohol cleaning solution. If you plan on opening the case at any stage please ensure the unit is disconnected from its power supply. If this fails and you are confident with electronics there are several videos on YouTube showing how to replace the drive if you choose to order it and do it yourself.Hope this helps. Please remember to rate my answer. Many Thanks.
1.You Should Try to clean your disks
2.put one in and go to games or videos depending on what u r doing and if your ps3 detects there is a game in there press triangle on the disk icon and select play
3.if that didnt work go to http://www.Playstaton.com/Support
Hope it Helped!
think your lens may be very dirty. And also please tell if the problem is only with this movie or all the other movies as well? moreover, if your lens is dirty, you'll have to clean it using a lens cleaner, OR get it replaced lens). I got my PlayStation's lens replaced when it was giving me trouble and all was fine after that. Best of luck.
Open up the PS3 and then open up the Blu-Ray Drive. Then clean the lens with rubbing alcohol or isopropyl alcohol on a q-tip. I heard that lighter fluid on a q-tip works way better than rubbing alcohol and isopropyl alcohol, so try using it on a q-tip to clean the lens. I'm not responsible for any damages to your console.
If that doesn't work then go here to get help from other people -
I have a PS3 and Rockband 2 and getting the following error "An error occured during the download operation (80710723)" and says you cannot perform background download of this content.
