Ran a diagnostic scan and 4 codes showed up in the scan,P0420,P0401, P0730, and P0401. Please tell me what they pertain to!!
SOURCE: Acura radio problem
get the serial number off the radio ,that is located on the radio itself that it to the acura dealer and they will run the serial number it the computer and give you the correct radio code ,the code you have is wrong, acura rob
SOURCE: obd2 codes
ur p0172 code refers to ur oxygen sensor, most likly the rear .. and the p0420 code is a catalytic converter deterioration code... the p0172 and 420 can be related because that oxygen sensor is the one installed in ur cat converter.....u most likely will need to replace both the cat converter and oxygen sensor
SOURCE: 2005 Acura RL fob code reset?
turn key to on,but do not start,press and hold the lock button for one second,turn key to off position,turn the key on and off three times ending the cycle with the key in the on position,press the lock button,you will hear the door lock cycle,press lock again to set code.
SOURCE: I have codes p1203-p1300 for 1998 acura rl
P1300 is ignition timing adjustment circuit failure.The P1203 is not listed in my Libary.If you think the code number is correct please connect your local Acure dealership, for referance to that code number.Good Luck.
SOURCE: What does the B2 code
IT is a "Time for Service Code" B2 Means its time for an oil change, Tire rotation, Cabin filter replacement and air filter replacements. Call your dealer or local Acura rep for an appointment. Hope this helps.
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
For
OBD code problems check the list of help links below. Click the link
below to go through its procedure.
Diagnostic Code P2195?
http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330?
http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330?
http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300?
http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768?
http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions
System codes details?
http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html
Engine Misfire codes?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
