Technics SL-1210 Turntable Logo
A
Anonymous Posted on Jun 01, 2014
Hi my new yamaha v373 amp needs a preamp to run a turntable so was going to use my previous onkyo txsv424 just wondering the best way to connect these two?
How \to connect
Audio Service Clinic
Level 3:
  • Technics Master 924 Answers
  • Posted on Nov 27, 2014
Technics Master
Level 3:
Answers
924
Questions
Helped
351371
Points
1710
If your new Yamaha does not have jacks labeled PHONO, and I doubt it does, you will need an external phono preamp to get the output level necessary for a line level input, which is 300 millivolts.
Grubhead
Level 3:
  • Technics Master 5,755 Answers
  • Posted on Aug 02, 2014
 Grubhead
Technics Master
Level 3:
Answers
5755
Questions
Helped
1662195
Points
11417
The turntable output cables go into the input of the magnetic cartridge preamp. The output ones go into an a tape in or aux on the Onkyo. I'm assuming that it doesn't have a input that says deck on it. Apart from getting some good quality interconnects between the devices it's a very simple thing to do.
2 Related Answers
mwarej123
  • 454 Answers
  • Posted on Nov 03, 2009
SOURCE: I have a Technics turntable SLL20 and I am trying
Yes, signal from a turntable is much lower than that from tape/CD.
michael
  • 155 Answers
  • Posted on Sep 14, 2010
SOURCE: I tried connecting my old Technics turntable using
you turtable will need a pre amp especially if you have a magnetic pickup cartridge
Hi I can't connect, read make turn table work, on my Onkyo TX-SR333, I have a preamplifier between the reciever and turntable but no sound possible thanks and regards, kees
Hello
what kind of a preamplifier you are using between the Turntable and the Amp.
please take a photos of the preamp from inlets and outlets.
so i can figure it out.
Regards.
1helpful
Can I connect a turntable with earth cable to an Onkyo CR515
yes you can but you will need a phono preamp such as the one found here.
http://www.turntableneedles.com/Phono-Pre-Amps_c_4.html
Hook the output of the preamp to Line 1 on the back of the CR515 and for simplest ground wire hookup, choose a preamp with a thumbscrew for the ground (earth) cable coming from your turntable.
Hello! onkyo SV717 pro amp that goes into protect mode. Any suggestions how to reset system?
Hi...
If you try JUST headphones (spkrs off), does it still go into protect?
If so, I would say ( from my previous 50 or so receivers) that it needs new power supply capacitors
If not, either one of your spkrs is faulty or they arent connected solidly at both ends
Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
1helpful
What do I need for my 1981 Technics turntable to play with an Onkyo TX-SR605
Hi, If your amp has no dedicated phono input you need to use a preamp to boost the turntable signal. You can then input via cd or aux input. [email protected]
1helpful
3answers
11helpful
3answers
ION TTUSB05XL - Poor sound quality
the turntable has a built-in phono preamp so you don't want to run it through phono inputs in your receiver but just regular auxiliary inputs instead
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
