Garmin nuvi 350 GPS Receiver Logo
A
Anonymous Posted on Jun 01, 2014
My garmin nuvi 200w voice stopped working - Garmin nuvi 350 GPS Receiver
5 Related Answers
Anonymous
  • Posted on Dec 21, 2007
SOURCE: garmin nuvi 350 troubleshooting
can't put in states, no matter just tells me no matches found
Anonymous
  • Posted on Feb 20, 2008
I have a garmin n 350 and I can't get it to mark my current location or map a destination. What am I doing wrong?
Anonymous
  • 47 Answers
  • Posted on Oct 23, 2008
SOURCE: Garmin Nuvi 200W
Hi!
This link will let you download ALL the manuals for this Garmin unit, not just the quick start:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00656-10
I didn't convert it to a Tiny URL, so make sure the whole link shows in your browser.
I would certainly appreciate a FixYa rating from those of you looking for the library, should you deem it appropriate. Thanks!
Bob
HarryHarley
Harry
  • 343 Answers
  • Posted on Jan 19, 2010
SOURCE: Garmin Nuvi 265w voice command stopped working.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
HarryHarley
Harry
  • 343 Answers
SOURCE: Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Do a RESET:
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
No voice garmin 200w Nuvi GPS
Tools ... Settings.... Language... under Voice select one that has an ending with ( TTS ) text to speech
No voice the speaker stop working
Go to Tools.....Settings....Language.... under Voice make sure Language with ( TTS ) is chosen
Voice not working on garmin 200w
Go to Tools ....System...Langage make sure you selected one with ( TTS ) ending
No more voice commands
Is it still under warranty
if so take it back to the store
1helpful
Voices "None Found" HELP!
You need to obtain a USB data cable to connect your Nuvi to a PC. Go to Garmin's website at www.garmin.com and download their webupdater program. Install it on your PC and connect your Nuvi to your PC. It will allow you to download the missing voices.
- Jim
SHARCNET-USA
5helpful
Garmin wont read street names anymore
To activate the voice prompts, go to 1. Tools, 2. Settings, 3. Language, 4. Voice Language Option, 5 Select a Voice Option that includes a persons Name, eg Jack or TTS, Select OK and that should resolve your problem.
Directional voice not operable
did you unintentionally turn the volume down or mute the volume?
1helpful
Deleted voice
Hello Sallilou,
If you deleted the voice files without backing them up you can try running the Garmin WebUpdater software. This program updates the operating software for your GPS and can be used to update maps and other files. It may be possible to reinstall the voice files using WebUpdater. (To download the WebUpdater software go here.)
Some of the Garmin products do have voice files available for download via the Garmin website. (Namely the Quest product.) However the Nuvi 200W does not appear to have such files immediately available for download.
If you aren't able to update the voice files this way I would suggest you give Garmin a call directly.
Best Regards,
Ken
"Go Ahead. Use Us."
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
