SOURCE: soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
SOURCE: bottle under Grohe soap dispenser leaks down to cabinet
Pull the dispenser out the top and have someone hold the trim above the counter while you tighen the bottle down below.
But the real problem is the retaiher nut which hold the dispenser in place is loose. Remove the bottle underneath ( it unthreads) and tighten the nut that you see just above the bottle. This can be a tight spot and you may need a basin wrench.
Please rate this response and Good Luck, Phil
SOURCE: Soap Dispenser leaks soap onto counter
maby minor crack between the the treds on the bottle that screws in to the pump or a crack in the bottom of the pump and you may not see it because the pressure of the pump isint in the bottle when you un screw it tot look at it
SOURCE: my grohe soap dispenser sticks.
You may be using too thick of a liquid in it palmolive is the worst to use in soap dispensers flush the head out with water if you remove the tube from it be careful alot of them have a ballbearing or spring inside or the unit is worn
SOURCE: my grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
