Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
A
Anonymous Posted on May 31, 2014
How long for red light to go off when the door has been open?
  • Frigidaire
    Frigidaire Jun 02, 2014
    Good Afternoon Friend, I understand that you want to know how long the red light stays on after you close the door on your Frigidaire freezer, model# FFU2124D. I will be more than happy to assist you. So I am able to better assist you, I would like to know where the red light is located, that you are referring to. Looking forward to hearing from you. -WP-
Shane
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 40 Answers
  • Posted on Jun 05, 2014
Shane
Contributor
Level 1:
New Friend:
Cheetah:
Answers
40
Questions
0
Helped
11469
Points
97
3 seconds or as long as it takes to get back to temperature.
Why is my green light on on my freezer
Green light usally means that the freezer is in good working condition. Red light means the door is slightly open and wasn't shut properly. Sometimes the seal on the door has gotten old or twisted.
May 11, 2019 • Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Door left open for about 90 mins on freezer now red alarm light is on all the time?
Good Morning Martin, thank you for your post!
If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
1helpful
The red light is on my freezer also the green one the door has not been left open can you help
This means the sensor has determined that the temperature is rising. This can happen if the door was left open (which doesn't appear to be the case with your green light) or an unusual amount of warm food was put into it. If this is not the case you may have a cooling problem. If you can put a thermometer in there and check the temperature, working properly the freezer should be around 0 F. If you have trouble please send the model number from the tag on the freezer. That will help with trouble shooting.
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
The light on my chest freezer will flicker on and off when I open the door. It will only remain on when the door is in a certain position. How do I fix this? Secondly, the red "on" light on...
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
Red light on freezer flashing
This means the temperature is rising and alerting you to have it repaired. Make sure no one left the door open and that nothing is keeping the door from closing and sealing all around. If these are okay I would need a little more information like the model number from the tag inside the unit to help figure out what might be wrong.
Apr 13, 2010 • Freezers
5helpful
2answers
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
My whirlpool afb 6640 freezer has a red light on
thermostat is defective(loose contact)
May 09, 2009 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
