SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
SOURCE: roper washing machine
Unplug. Remove 2 screws on both back corners of top acess panel. Slide panel foreward and lift up. It will flip back out of the way. Unplug door switch harness. Pull up on and remove 2 retainer clips that attach backing plate to body. Pull up from back and remove housing.
SOURCE: my roper top load washing machine will not spin.
Hi There,
You need a new timer. Hope this helps and thank you for using FixYa!
SOURCE: i am trying to get access to the top front of
this video will help you how to remove your top front washer mishine.
http://www.youtube.com/watch?v=vogysB7XOc8
Thank you
Yourratting is very important for me
Was this helpful?
SOURCE: ROPER TOP LOADING WASHING MACHINE
Sounds like the water valve stuck and humming trying to open. Check voltage at water valve should have 110 volts. If you have voltage replace valve.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
