Question about Sony Playstation 3 (PS3) Console
My playstation 3 will not play disc i replaced cd?
My disc quit working and i replaced and it still will not work
  • Anthony Ward
    Anthony Ward Jun 12, 2014
    Hi Karen Horner, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Did you replace the drive with a CD drive or a Blu-ray drive and are you trying to play CDs or games?
Your ps3 laser is definitely on the frits or completely fried. it tends to happen to ps3 more frequent in dusty or smokey homes or rooms. not much you can do it cost overe $100 to fix when you can buy brand new one for $100 more. the problem is fixable but my opinion a new one is a better option. you can still use the burnt laser ps3 to watch netflix or other forms of files not dvd or cd
Posted on Jun 10, 2014
    New Friend:
    Problem Solver:
  • 6 Answers
I made this same mistake myself. if you are talking about a pre 160GB machine. in those PS3s the main control board inside the bluray drive is hardware locked to the main motherboard of the playstation. you can still change the drive, but only if you take the control circuit board from your old bluray drive and swap it into your new bluray drive. I know this seems to defeat the purpose of the new drive but in my experience the board is probably not the cause of the initial change. believe it or not, this is a relatively simple operation if you have enough wits to already have swapped the drive. just as always note positions of things and proceed gently and you will be fine.
Posted on Jul 20, 2014
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Laser fault
Posted on Jun 11, 2014
  • Richy GC
    Richy GC Jun 11, 2014
    Laser fault
  • 31 Answers
Laser probly bad you can buy a replacement laser on ebay and changed it you need to buy one from correct model there are several different models and different ones however
Posted on Jun 07, 2014
    Problem Solver:
  • 9 Answers
Did you take it to a technician to get the LENS or the Bluray Unit replaced? Cause if the Ps3 wont read ANY disc then your bluray unit is dead. You need to replace either the lens or the drive.
Posted on Jun 05, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Doesnt read any discs(blu-ray,dvd,cd).
Go online and reformate console
Posted on Mar 24, 2008
Anonymous
SOURCE: playstation 3 wont read some cds or play downloaded demos.
I'm also having this problem as well, it has to do with the OS and it is corrupted. It seems like the "Game mode" has been corrupted preventing us from playing games on the hard drive or reading games.
Posted on Aug 09, 2008
Anonymous
  • 16 Answers
SOURCE: problem with playstation 3 games and blue-ray
I had a similar problem. My PS3 was not starting the game discs when I inserted those to the PS3. Also those game discs were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Actually I was able to start the game disc with a special trick, which required start some application, such as a downloaded game, let it start, and then hit the PS home button. The game disc title then shows up under the game menu and from that point remains viewable until the disc is ejected or the console is turned off.
In case you have the similar problem, I was able to fix this problem by executing the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After the PS3 has executed this DB rebuilding operation, the disc games will be visible again under the game menu and are also starting automatically when inserted to the PS3.
Posted on Jun 17, 2009
RixsFixes
Radio Code Pro
  • 2200 Answers
SOURCE: My Playstation 3 suddenly stopped working whilst I
This is a very common problem with the PS3. I have outlined the key issues here on my FixYa Tip. Please click the link for a full explanation of the problem.
http://www.fixya.com/support/r3582526-sony_ps3_not_reading_disks_or_games
Many thanks for using FixYa
Posted on Dec 05, 2009
Anonymous
  • 1093 Answers
SOURCE: Playstation 3 won't load games or Blue Ray Discs
This is normally because the laser on the drive is slightly off. The good thing is that you can fix this yourself it is quite simple.
Or of course you can send it in to be fixed it is up to you.
If you send it in you will have to pay out about $130 to get it fixed.
Posted on Feb 05, 2010
My playstation 3 cd drive will not play disc i just replaced cd
Check the disk for scratches. PS 3 &PS 4 Game systems may not play scratched games even if it is replaced. It is best to just buy the replaced game New to solve the problem.
Hope this helps you.
Jun 01, 2014 | Sony Playstation 3 (PS3) Console
My ps3 plays movies but not games what can i do to fix it?
First make sure the game disc is not scratched or dirty. Get a cleaning kit and use it to clean the laser off inside your PS3. If it still don't work after you clean the optical drive then your diode has burned out (a very common problem with the PS3). The PlayStation 3 uses two different lasers to read a disc. One of the lasers inside is used for standard DVD's and CD's and the other one is used strictly for playing Blu-Ray. You will need to replace the standard laser to get your games playing again.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
Not playing blue rays and now has stoped plating games
First make sure the CD/DVD is not scratched or dirty. Get a cleaning kit and use it to clean the laser and disc off inside your PS3. If it won't work after you clean the CD/DVD then your Blu-Ray Diode has burned out (a very common problem with the PS3). The PlayStation 3 uses two different lasers to read a disc. One of the lasers inside is used for standard DVD's and CD's and the other one is used strictly for playing Blu-Ray. The only way to fix your PS3 at this point is to replace that Blue Ray laser. If you do not have electronic repair knowledge I would recommend paying the $150 to have Sony replace it. Your PS3 is under warranty for one year from the original purchase date.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not play games but will play music cd whats the problem thanks
ok the way to fix your ps3 not reading discs is to clik on a demo the quit out and your game should pop up.if that dosent work your going to have to loose your data go to restore ps3 then when its at 1 percent cancel and the the ps3 will restart and it will ask if u want to format and loose your data click yes and your cd problem will be solved for more answeres or question just ask
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
It will play DVD's & CD's.But NO games!
I HOPE EVERYONE READS THIS AS IT'S LIKELY A (FREE) SOLUTION TO YOUR WOES.
My ps3 recently conked out on me and the local game store (and the internet) told me it was a broken laser.
I told them that I couldn't play video games, not even ps2 games, but that dvd's could still be watched (check to see if you can do this). They still said it was a broken laser.
When I found out it would be 140 bucks to have it replaced and installed I decided to just download some demos.
HERE'S WHERE IT GETS INTERESTING.
I went on the playstation network (psn) and downloaded a game demo, installed it, and played it. When I quit out of the demo, the laser was reading and I could play games!
When I turned off the system and tried again the next day, again it didn't work.
I followed the same process. Went into a downloaded game, this time quit right after the demo loaded, and sure enough, the laser was working again!
Every time I quit a game I have to follow this process, but every time it works, too.
So again:
1. download and install a psn game or game demo
2. put the disc of the game you want to play
3. load the psn game or demo as if you were going to play it
4. quit the demo as soon as you get to the start menu of it
5. go and play the game you wanted to, sucka, cause it works now!!!
I hope this works for you, and if it does, spread the word!
Feb 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will play regular dvd discs but no games whats wrong?
It's quite likely due to a weak Blu Ray laser. The DVD and BluRay are 2 different lasers so it could still be able to read and play DVD/CD but not the BluRay games.
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
PS3 is not reading any discs I insert into the system.
The following types of discs can be played Blue Ray Disc - Playstation No 3 format BD-ROM, BD ROM,BD-R, BD-RE DVD - DVD-ROM, DVD+R/RW, DVD-R/RW, AVCHD, DSD disc CD - Playstation format CD-ROM,CD-DA (Audio CD), CD-R/RW
Also Check the regional code on the disc which should be compatible with the regional codes which can be played by the PS3
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Cd player quit working
TRY LASER CLEANING DISC. FAILING THAT IT COULD BE THE LASER HAS DIED OR SERVO PROBLEMS.
Jun 19, 2009 | Emerson MS9825 CD Shelf System
My playstation wont play any discs at all
It's a Sony defect. Drives only last 1-3 years, sometimes less, with average use.
That's the number one problem that I see with the PS3.
Check out my blog for help fixing the problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 won't read or play disc
Send the system back to Sony for repair as this sound like a complex problem that cannot be solved easily.
- John
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
105 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
