paper out sensor not working it's possible
SOURCE: HP 5510 All In One. Error message Paper Jam when
Have you changed the paper properties to reflect that you are using a heavier weight paper?
If not, then the printer might not be set right for the paper you are using and that can cause the problem you are seeing.
SOURCE: HP 5510 says clear paper jam. There is no jam
verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Testimonial: "I haven't tried it yet because it is no longer hooked up but I will. Thank you for your input."
SOURCE: Error message printhead missing HP photosmart 5510
This indicates that your head is not correctly installed.
Clean the contact surface with a tissue paper then try to insert it until it snaps in place. On hp printers the ink cartridge is the print head.
hope it helps
