Vehicle nissan micra 2012 model when standing dead still at robot while car are idleling while break is apply knocking noise in front under bonnet both sides knocking at both lights
This fault is a bit srange, when you apply the brake pedal you here a
"Knocking" noise from the front of the car, alternating from one side to the other, the cause of this is a bad earth in the rear light clusters,
which results in the headlight motors activating "Jumping" thus causing the noise, solution is to clean the conections and conecting
blocks of the rear light clusters in extreme cases change the rear light clusters but a good cleaning should fix it hope this was helpfull
SOURCE: 1998 NISSAN ALTIMA FRONT END NOISE / RT SIDE GRINDING NOISE,.... BEARING?
CV joint has gotten debris and moisture inside. The CV boot is bad and not protecting the joint. Now its metal on metal grinding. This happens when turning as there is more pressure on the joint. Please fix this ASAP as it can be dangerous to drive on a bad CV joint. While I have seen people drive with a bad CV joint for over 4k miles, it is NOT recommended!
SOURCE: 1995 nissan quest minivan gxe v6 - noise under the hood
low or no oil pressure... check the level of the oil .. add if necessary and have the oil pressure checked
Robert
SOURCE: replaced front brake pads and also two studs
Well this is tricky. I have no idea what this could be except for the bearings. The reason I suspect this is because turning and braking will change the pressure you put on each wheel, so reducing or increasing pressure on that specific wheel could make a new noise.
SOURCE: blower heater unit in micra k12
hi did you get the resistor fixed if not you need to remove the glove box by removing the screws that can be seen then there are two plastic lugs that need to be pulled out sideways to enable you to remove the glove box then you will see the resistor card on the side of the motor thats on the new shape micra k12
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It
can be fuel pressure issue or it's the problem with accelerator pedal or its
clogged filters causing there.
There
are many other possibilities. I suggest you to go through the list of help
links mentioned below, these will help you to confirm where the actual fault
lies: -------
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
There
are many possibilities that can cause car to make noise.
It's
actually from where the noise is coming from. Front end or rear end. From
engine area or from inside the steering or from brakes.
There
is N-number of possibilities for the car to make whining noise or any other kind
of noise.
For
step by step troubleshooting this problem, I suggest you to refer the help
links mentioned below. Its a complete solution with proper explanation to
identify the cause of problem: ------
Click
the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like
driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for
Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud
noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in
the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under
dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and
front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan
belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While
Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
