SOURCE: Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
SOURCE: i need clx 3170 quick guide manual can you
http://www.samsung.com/download/Model_Select.aspx?type=Multi+Function+Printer&typecode=16&subtype=Color+Laser+MFP&subtypecode=1604&model=CLX-3170FN&filetype=UM
Try this link...it looks like the quick guide is in .zip format for fast download time. Hope this helps.
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
SOURCE: i have a samsung clx 3170, the display appear
go to:here:/www.compute.co.th/forum/index.php?board=17.0
SOURCE: setup samsung clx 3170 on shared network
yes
if u use wireless printer u receive n send document via that printer.
