CAN YOU TELL ME IF I NEED TO WAIT A PERIOD OF TIME BEFORE TURNING ON MY AC WINDOW UNIT BECAUSE IT WAS LAYING ON ITS SIDE PRIOR TO INSTALLATION?
SOURCE: Install a outside A,C. unit(heat pump),
sounds as if you either have an improperly working thermostat. If this is new, the low voltage wire in the air handler may be improperly connected, or a bad sequensor.
SOURCE: Frigidaire AC Window, Model # FAC107P1A2
you have clearly mentioned in your question itself that electrical cord does have power going into the unit.i feel it may be the problem with your power cord wire . try replacing the cord first and check whether the power reaches the unit.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
SOURCE: my out side ac unit runs all the time
You have a low voltage short on the unit somewhere telling it to come on. Or the contactor on the outdoor unit is stuck closed. You can turn the power off to the unit ouside and open the cover. Look at the contactor and check to see if it is sooted or burnt. Those are the only two problems that it can be.
SOURCE: ac unit not turning on
Chances are your A/C unit can be repaired for a lot less than a new one -- I'd call for service.
SOURCE: Installing a window A.C. unit by maytag
no it shouldn't matter,just insulate the gap so you dont loose cool air,as for the draining problem tilt it some more,and make sure drain hole is open and not plugged that should fixya
