It seems like the main board is not turning the back light circuitry on.
Check the Back Light On/Off at CN803 pin/wire 6 you should measure 0V - 4.9V with 5Sec Delay.
Let me know if you require further assistance.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
You haven't mention your Operator name of at least the country. I Assume that your are from Asia-Pacific Region. Below link gives you a list of Mobile Operators from the region. Select your operator and go to their web site. you will find more info in there.
just search automatically the local channels(scan)on your search mode.click asia pacific region or just asia on your menu.but don`t forget to set it to auto system and the sound for ntsc3.58 system so that you can get clear sound.or your antenna doesn`t install correctly?please check it first
No,there is not a such thing as this box.All Asia countries used PAL tv signal frequencies.Check the cable box?Tries unplug,replug cable box back like about an hour later,see if this work.
