SOURCE: garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
SOURCE: My Garmin Nuvi 255 died. How do I reset it?
Hello there:
If you unplug the unit and remove the battery
i would check the fuse inside the unit to be sure that it is ok if it is than
leave it unplugged and the batttery out for 30 min and if there is a reset button on this after the battery is removed hold in the reset in for 2 minutes then after the 30 min replace the battery and plug in the unit and try it again his should be enough time for the internal reset to reset it'self than just replace the battery and if this still oes not help remove the battery again and leave it sit for 1 hour to let the internal reset device reset it'self ok and you should be good to go
Hope this is very helpful
Best regards Michael
SOURCE: how to change language on a 255?
On the very first screen after the GPS boots there will be an icon of a
wrench at the bottom right of the screen. Press that Icon and scroll
through the menu and you will find a language setting.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Testimonial: "Thank you! Merry Christmas!"
SOURCE: My Garmin Nuvi 255 doesn't appear to have a reset
Owner's Manual Rev. D, Sep, 2009 (Click here) Download
See page 42 of the manual to reset your device.
" If your nuvi doesn't have a reset button, slide the power key to the on/off position and hold it for 8 seconds."
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
SOURCE: how to reset my garmin nuvi 255.
You should be able to find the reset button near the SN #. Press it to reset your GPS.
