SOURCE: GE SSS25KFMD SIDE BY SIDE
you might have a bad water valve that it wont close since your just repl ice maker then try to repl water valve at back if is leaking then the fill cup will be full of ice and also it will be over filling the ice maker mold
SOURCE: GE PROFILE PSS26msrd Ice maker
if the water dispenser is working normally and ice is not producing, take thr water filter out rinse it with hot water and put it back, this is the important thing to do after you put the water filter back you must hold the water filter reset button at least 3 seconds to reset the system and it should working fine.
SOURCE: WR30X10093 Icemaker problems
Remove the white plastic cover. Upper right screw sideways with + and - on the head. This is the fill adjustment.
SOURCE: GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
SOURCE: Icemaker water overflows into freezer
The problem is really that the GE icemaker
WR30X10093 has a design flaw - there is a heating element located below the ice cube tray (which heats the tray to get the cubes out), but there is no guard of any sort below the tray. Since there is no guard below that heating element, the element heats ice that has accumulated near the element and starts melting it. Then, when the cubes are popped out, the partially melted ice re-freezes all the cubes together.
I have the same problem. :(
