Question about Rainbow E series Canister Wet/Dry Vacuum
How do i put the wand back together on a rainbow e-series ?
I had a wire come loose in the wand and have had to order another trigger switch. I have two unattached wires and don't know where they go ?
    Sergeant:
    Habit-Forming:
  • Rainbow Expert
  • 138 Answers
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
Posted on May 31, 2014
6ya staff
SOURCE:
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Posted on Jan 31, 2008
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Rainbow SE Power Switch
The 2 clear side panels come off, remove the screws there, then the top will come off and you can get to the switch from there also.
Posted on Feb 05, 2008
Anonymous
  • 25 Answers
SOURCE: Rainbow SE (1991)
little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
Posted on Mar 26, 2008
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
Posted on Mar 16, 2009
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: I have a Rainbow D4C.
Changing polarity on the cord will not change anything. Three phase power would be the only way to change the direction of the rotation.
Posted on Sep 19, 2010
How to replace a rainbow vacuum activator switch
If you remove the screws holding the handle pieces together you can separate them and remove the actuator and put the new one in the same place, then put the handle back together.
Mar 12, 2018 | Rainbow Vacuums
How does the nonelectric hose detach from the wand on rainbow e series to connect to aquamate
Rainbow E Series attachment hoses fit the wand with friction. The wand will just twist and pull out of an attachment hose. Now for use with an Aquamate, if you have the newest aquamate like here:
Rainbow AquaMate 3 carpet shampooer , the aquamate needs an electrified hose made for water pickup and a stainless steel long pipe (stainless steel so it will not rust, you can use chrome but it will rust) .
Vacuum Repair Technician
800-775-6586
GoodVac.com
Feb 17, 2015 | Rainbow Vacuums
Need instruction to replace circuit breaker for Rainbow E series..
The factory has stopped using the circuit breaker in the power nozzles. Reason is that it is redundant as you can turn power nozzle off with the trigger in the handle if you get something caught or have an issue. Just wire all the leads together and bypass the reset button.
RainVac
www.rainvac.com
800-523-0510
Aug 27, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Mar 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE (1991)
Mar 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Power head handle wiring
Not sure, I had a chance to look at one earlier, there was a wire that came off of the hose and went to that point above the trigger. Is that wire by the trigger intact or broken off? I may be able to look it again on Monday.
Feb 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
437 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Robert McClure
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
