Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Quiet Pak 2 He 3 and it is very loud when spinning. It sounds like the drum might be out of place. I went to spin the drum with my hand and it's ok until a certain point and it makes a sound and is difficult to turn. What should I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenmore Master
  • 721 Answers
Okay the bad news is most likely the bearings in the back of the front load drum are damaged and there may even be some cracking in the back this is causing it not to spin properly it will not be able to work for much longer and if you would need a major repair to fix many cases it is not worth fixing front loader because the average repair cost is around $400 you might want to get it looked at by an appliance professional but most expensive see the links below for more information Replacing the bearings on Kenmore HE3t front load washer Part 1 By How to...
Posted on Mar 05, 2018
6ya staff
SOURCE:
Washer_tech
Geoff Siegel
  • 164 Answers
SOURCE: washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Posted on Aug 16, 2007
Anonymous
  • 261 Answers
SOURCE: KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Posted on Oct 23, 2008
Anonymous
  • 63 Answers
SOURCE: clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Posted on Nov 14, 2008
Anonymous
  • 63 Answers
SOURCE: Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Anonymous
  • 99 Answers
SOURCE: Washer hasn't completed the spin cycle and is flashing 02 then f
this is joyce
what kind of waher have you got? model #
Posted on Feb 06, 2009
My Kenmore Elite Quiet pak 2 # 11045872402 HE3 washer doesn't go through the complete Cycle it stops when drain and spin,or doesn't Tumble through the cycle? could I have confused it by trying to keep
Spinning is prevented when the cover is open. Possibly a broken "door closed" switch is or its wires are broken. Lift the lid platform and check the switch. May be just debris preventing it from engaging. Remember, the lid and the close switch must be engaged before the control circuit will allow the high speed spin from happening. This is an essential safety feature and should never be circumvented. A high speed drum can literally pull an arm from its socket if caught so make sure it's working properly
Feb 16, 2017 | Kenmore Washing Machines
Kenmore elite quiet pak 2
No it is very expensive to repair. You have to buy the whole rear portion of the outer drum if it is the bearings. Or a tub spider which holds the inner tub to the spindle that spins it. it is a very labor intensive repair. you would also need the outer tub seal/gasket for reassembly. If you are a skilled mechanic you may be able to repair it cheaper than a new one, but be prepared to spent the better part of you weekend working on it.
Nov 16, 2013 | Washing Machines
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore elite oasis dryer quiet pak 2 making loud screeching noises-
Either your glide pads that the front of the drum rides on are worn out, or the rear drum bearing are worn out
Mar 24, 2011 | Kenmore Dryers
Kenmore elite HE5t quiet pak 9 washer kocks when spinning. I thought something was lose but did not find anything. it will run to completion but get very loud for a short time. Is there some kind of...
I think possibly your machine is not on a level surface. Try rocking the machine, if it wobbles, the feet need adjusting to level the machine. It will cause damage in the long run if not levelled.
Dec 09, 2010 | Washing Machines
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Dec 11, 2008 | Washing Machines
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
158 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
