Master
- Posted on May 31, 2014
Re: Forget the code for enter parent lock i no remember...
Instructions
- 1Put the screwdriver into the screw hole in the small panel on the back of the Leapster. Remove the screw, and open the panel.
- 2
Remove the batteries from the Leapster and discard them. Find the small "reset" button behind the panel cover. The reset button should be black or red
- 3
Press the reset button with the pointed object. Hold the button down for about three to five seconds.
- 4
Put fresh batteries into the battery chamber. Make sure the flat side of each battery connects with the springs in each battery channel. Screw the panel cover back into place.
- 5
Press the Leapster's "on/off" button. When the Leapster comes on, enter the country information and the player's name.
- 6
Press the "hint" button, which opens a pop-up help menu. Press the "A" button. Use the stylus to touch the center of the small crosshairs on the screen to calibrate the touch screen.
Read more: http://www.ehow.com/how_8430044_reset-leapfrog-leapster.html#ixzz33FgzCf1j
