SOURCE: Lenovo Notebook Problem
Sorry, there isn't a way to get past the password other than to contact Lenovo. Resetting the CMOS will do nothing. They will ask for proof of ownership before they do anything. I believe they have a "backdoor" password.
SOURCE: how to remove bios password in lenovo 3000 y510
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: Hi, after forgetting my Lenovo x200
the thing you are done is a old bad idea. its wont work out rather than doing these things try to remember the password
SOURCE: how to remove bios password from lenovo t410?
email me at [email protected] for specific directions.
_____
/ _ \ ___________
/ /_\ \_/ ___\_ __ \
/ ' \ \___' ' \/
\____'__ /\___ >__'
_________ .__ __ .__
/ _____/ ____ ' ' __ ___/ '_'__' ____ ____ ______
\_____ \ / _ \' ' ' ' \ __\ '/ _ \ / \ / ___/
/ ( <_> ) '_' ' /' ' ' ( <_> ) ' \\___ \
/_______ /\____/'____/____/ '__' '__'\____/'___' /____ >
