When Frigidaire 50 pint dehumidifier is plugged in, compressor comes on, but not blower wheel. Blower wheel starts spinning after pushing "On" button, but stops after 2 minutes, while compressor continues running. Compressor will not turn off unless unit is unplugged.
This energy efficient dehumidifier features a front loading bucket with a carrying handle and slash guard with casters for easy portability. A washable, anti-microbial mesh filter removes both moisture and airborne particulates, keeping your space clean and dry. Two fan speeds further customize use. Featuring full-function electronic controls with a digital humidity read-out, full bucket indicator, delayed start, and a 24-hour timer, this 50-pint dehumidifier offers easy operation. The 16.3-pint water bucket has slide-out access on the unit. This Energy Star rated dehumidifier is capable of continuous operation when located near a suitable drain. With premium features including auto shut-off and convenient cord storage, this powerful dehumidifier is well-equipped to remove moisture from the air and create a comfortable living environment.
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
