Maytag Neptune MAH7500WH Front Load Washer Logo
A
Anonymous Posted on May 30, 2014
I stopped the initial cycle after the lock was set to add one more item. Now the washing machine will not operate/ start again
What can I do to reset - start the machine?
Just Appliance Repairs
Level 2:
New Friend:
  • Expert 76 Answers
  • Posted on May 30, 2014
Expert
Level 2:
New Friend:
Answers
76
Questions
0
Helped
50613
Points
143
This could be caused by a couple of things. The most probable is that the door switch has failed and will need to be replaced. This could be also caused by a failure of the control board, but this is not nearly as likely.
Unplug unit for a minute or 2 and try again and make sure the door is completely shut. If this doesn't help, the door switch is the next thing to look at. I hope this helps.
5 Related Answers
A
Anonymous
  • Posted on Oct 30, 2007
SOURCE: washing machine maytag performa
This problem is normally attributed to a combination of two things: A worn out snubber ring, and a worn brake assembly.
The snubber ring assembly is a white teflon ring that sits under the wash tub at the base (called the milk stool, because it looks like an upside down milk stool).  The entire wash tub assembly will rest on the snubber as it helps get rid of vibration while the tub agitates and spins.  When the snubber starts to wear down, you will notice an increase in tub vibration during the spin cycle and it will sometimes begin to squeak. NOTE: YOU CANNOT OIL THE SNUBBER! DOING SO CAN CAUSE MORE DAMAGE.
The brake assembly is mounted between the pulley wheel and transmission under the washer.  As the brake assembly ages, the pad (which is mounted along the rim of a metal disc) begins to glaze over.  As it glazes, it will also squeak and cause the sudden "slamming" to a stop.  The glazing, coupled with humidity in the air can make this condition worse.
Both problems occur normally with this model washer and can be attributed to normal wear and tear.  I recommend replacing the brake assembly and snubber at the same time.  You will need, however, a special Maytag brake removal tool and spring removal tool if you decide to attempt this repair yourself (it is possible to accomplish this without the aid of a repairman).  Let me know if you need further assistance.  CAUTION: THERE IS A 200 LB COMPRESSED SPRING UNDER THE BRAKE HOUSING.  ATTEMPTING TO REMOVE THE COVER WITHOUT THE BRAKE REMOVAL TOOL CAN BE DANGEROUS.
Anonymous
  • 290 Answers
  • Posted on Nov 25, 2007
SOURCE: Door will not lock to start wash cycl
This sounds like a classic door lock problem. There was a design change in the lock assembly because of numerous problems.
You say you had the door replaced, did they replace the lock assy also?
The control puts power to the wax motor that operates the latch. As the door locks, the latch activates the lock switch that tells the control the door is locked.
What kind of reading are you getting on the lock switch?
Thanks/Mike
Anonymous
  • 196 Answers
  • Posted on Jan 13, 2008
SOURCE: whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Anonymous
  • 770 Answers
  • Posted on Jan 24, 2008
SOURCE: Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Anonymous
  • 1073 Answers
  • Posted on Apr 21, 2008
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
How do I soak items overnight in my LG WT517OHW washer
  1. Load the items you want to soak into the washer drum.
  2. Press the "Power" button to turn on the washer.
  3. Press the "Pre Wash" button, this will start a pre-wash cycle that will last for 5 minutes, this will give you the time to add any detergent or laundry pre-treatment solution.
  4. Press the "Start/Pause" button to start the pre-wash cycle.
  5. Press the "Delay Start" button to set the time you want the washer to start the main cycle. This will give you the opportunity to soak the clothes overnight
  6. Press the "Start/Pause" button again to start the main cycle after the pre-wash cycle is complete.
  7. Leave the items in the washer overnight.
  8. In the morning, press the "Start/Pause" button to start the main cycle again.
  9. When the cycle is complete, unload the items from the washer and dry them as usual.
  10. https://www.lg.com/in/support/video-tutorials/CT20150045-20152230657216
How do I remove the locking function on my washer when already begun cycle so I can add an extra item I forgot put in without having start again. Is it possible?
On later model front loaders they have a Stop & Add button so when engaged you can add more to the wash load. Unfortunately earlier washers don't have it so once the cycle starts that's basically it. That's the reason some people prefer top end loaders as it not a issue
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
How do you soak whites in this washing machine. I do not have a soak cycle
Hi I tried to answer you but somehow I think my answere was lost so I will try again. I think you should be able to add the clothes and detergent that you want to the machine. Start it normally and when the wash cycle starts, simply stop the machine and let it set for as long as you want then start it up and let it finish the wash cycle. Have you checked the operators manual? How about taliking to someone from the store you bought this at, they might be able to help you with the specifics of your machine.
2helpful
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
